Small left offset appears when playing an app streaming video (like Netflix or Amazon Prime)
I have noticed, not always, when I play a video streaming (in Netflix or Prime, or HDMI source...), sometimes it appears a little left offset (always in the left) 2cm aprox, and the right offset is OK, and I don't know is an auto-resizing image or another cause (video resolution adjust, ...), because as I said, it does not always happenIs it same for everyone?
Sony KD55AF8
Thanks in advance.
Tags (1)
1 REPLY 1
The_Black_Rose
Specialist
Hi victor.sanchez.ecm2,
I'd recommend turning off the info banner function by following these steps:
1- Press on the Home Button on the remote control.
2- Go to Settings.
3- Go to Channel Set up.
4- Turn info banner off.
Let us know if this has resolved the issue.
Cheers,
The_Black_Rose
