Sony Bravia KD43XF8577 Recording to USB HDD
romanchi
I puchased this TV about 2 weeks ago. Having discovered that I can't use the record to HDD in YouView mode I disabled YouView. When I tried to return to YouView mode the TV had to go through the whole setup again including a full autotune.
Does Sony expect me to go through this process every time I want to record something - if so they can't be serious! Or, am I doing something wrong? Would like to hear from anyone who has used this feature without problems.
3 REPLIES 3
Anonymous
Not applicable
Hi there,
Hopefully one of the community members will be able to help.
Best wishes,
M
batee5
Specialist
Hi romanchi,
Welcome to our community!
I think you already know by now that it's not at all possible to record content on an HDD connected to your TV while having YouView enabled. Unfortunately, there's no workaround for  it as enabling YouView removes the recording section in the settings menu.
Regards,
Batee5
romanchi
Thank you for your responses.
As you say I'm aware now,  but I don't think much effort was made to explain to me that using this TV in YouView mode would disable the recording function. Incidentally, this is Sony's choice to not make this available, not YouView's. My old YouView box (from BT) allows me to record. Disappointed but lesson learned.
