Re. the above TV which worked perfectly on Freeview until I foolishly attempted to upgrade the firm ware, suddenly Youview appeared, attempting to re-arrange channels etc. it asks for my code number, on idea what it is because I have never inserted a code. Recently, whilst viewing programmes, a signee appears "due to inactivity the tv will shut down, press any button to continue" I do that, but it shuts down anyway.
Basically I want to remove Youview and revert to Freeview.
I would be grateful for any advice on how to do that and thanks in advance.
Emyr Davies.
On 2020 sets and later, it is simply a matter of exiting ‘Live & Catchup TV’.
Hey @19JED38, which firmware version is currently installed? Is it 6.7215? Have you tried removing/inserting the aerial, then re-tuning the channels and checking again? Also, if you've followed the above steps to disable YouView and the problem continues, I'd recommend a factory data reset.
Piscie.
Thanks for your reply, it looks like a factory re-set is the only solution, I will wait for one of our grandsons to visit, they know far more about these things than I do.
Thanks again.
royabrown2
Thank you for your response, when I click home and select settings - watching tv - I get - internal inputs, no sign of channels or channel settings.
Conclusion - I will do a factory data reset.
Thanks again,
Hey @19JED38, keep us updated with the result of the factory reset. The channels option is available in the settings list. Make sure you are using the Sony controller, then select Settings - Watch TV - Scroll down to Channels - Channel setup - YouView setup.
