I use MusicBee for my audio playlists, which include spacer files of 1s, 2s and 3s silences. The spacers play just fine on my PC but when I use MusicBee to cast to the TV the music files play fine, but the spacers cause playback to hang, meaning I have to manually skip the files - which is a real pain. I assume the TV cannot cope with very short audio files, but it would be far better to skip these files rather than hang. The spacer files are 7kb, 9kb and 13kb respectively for 1s, 2s and 3s of silence.
Please look into this problem. As I said, the issue is that playback hangs, I'd prefer the TV just ignored the problem files. I can provide the files if that's useful.
Hi jeffer, idk why I felt the need to tell you that this is a user based community.
Anyway, what's the model number of your TV? Also, what happens if you played audio files without these spacers included?
