Sony Bravia turns itself on randomly
lukefildes
Hi
I have just bought a Sony Bravia KD49X83 4K Ultra HD Android TV. I have a problem where the tv just turns itself on all on it's own at any hour randomly. I do not have any timers set. Does anyone else have this problem
There are no lights flashing or anything
Thanks
59 REPLIES 59
JT4444
My googling has led me to believe,  that the router is causing the tv to turn on somehow.
Some kind of power issue,
I also have a power issue with the usb connections, power is constantly on!
I cannot leave any usb plugged in to the tv, because the power is constant, the disc Is constantly spinning, even though, I'm not using or accessing the usb drive.
Any ideas? Any help?
JT4444
And then what?
I need the tv to be connected to the internet.
Im supposed to be able to use the tv this way.
Thank you
profile.country.GR.title
MiCal1967
Contributor
@JT4444
I think it is a good idea first of all to know what causes your issue.
About the HDD, did you try a second drive? Mine goes OFF a while after TV is powered OFF(STBY).
Did you check your Sync settings as Quinnicus mentioned before? Try disabling syncing.
Also check this:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/23719/kw/usb
and
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/109742/kw/usb
and
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/79852/related/1
lukefildes
Mine used to turn it's self on it was resolved by playing around with the sync settings. When my cable box started recording something and coming out of standby was resulting in the tv turning its self on
Get Outlook for iOS
anclaus54
 This is also happening to my new Sony 55XD9305 and none of the solutions above fixes it. I have got nothing attached to the TV and I'm usin wi-fi to connect to the internet. Surely this is a firmware problem that Sony needs to look into.
Any updates Sony?
Anonymous
Not applicable
Hi there
Unfortunately this is a known issue.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2115486#M40757
chapplerm
Hello,
We have had the same issue with our new Sony TV.  We used NetFlix and if I just turn off the TV without exiting the application the TV will switch on ramdomly.
However we have tried a number of different things and exit from NetFlix works for us give it a try if you haven't already.
Rob
colilee98
I've had this problem but only since the latest update in the last few days (v3.473, released on or after 19/07/16). I've tried your suggestion and I'll see how it goes. Thanks for the input.
Edit: hmm, that didn't work. I've turned the sync off entirely now.
colilee98
Damn thing came on again last night despite synch being off entirely, the wife just plugged it out of the wall. This morning I plugged it back in and left it on standby where it stayed for an hour and a half so perhaps the trick is to plug it out for awhile and let it boot back up. I'll try it again tonight and confirm either way.
chapplerm
Do you use Netflix?
If so press the back button until you get to a menu where you see exit application. This has fixed this issue for us on our to.
Sent from my iPhone
