Sony KD-55 A1 Shadow in Corner of Display
Kevw114
Resolved with a panel refresh, accessed from the remote control >Home>Settings >Display>Expert Panel settings>Panel Refresh.
Note, it takes one hour to complete, screen is blank and power light goes off, once started leave to complete otherwise it will show A failure message and option to start refresh again.
IamNic
Hello @Kevw114,
thanks for sharing this tip.
- Nic
1 REPLY 1
IamNic
Hello @Kevw114,
- Nic
