Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Please message me the solution too. Even when upgrading by USB , it stops after 70% and reboots
2015 KDL-50W950C model upgrade stuck and reboot after 70%. Will appreciate your help
Hello!
I have the same problem. Please, can you send me a solution?
Best Wishes
Anton
Hi request you to email me the solution email to update the Bravia tv to sail@live.in
привет, у меня sony Sony KD-55XE7096 ,при в ютьюб не заходит, и каналы в оттоплайере не показывает выдает ошибки 2123 и 409.. поможете мне?
Hello, I have a problem, error 2123 on the Sony KDLWD653 TV. The community says that you can help
Hello please, I need some help, my tv has 2123 issue, can you help me?
Hi !
Could you help me with a problem equal this?
My TV is a KDL-48W655D.
It lost the connection with the Internet today when I tried to use the Netflix.
The message is: An Network error occurred. <2123>.
Could you send me the solution to the problem mentioned in this article?
I would be thank you so much!
Best regards!
Hi Quinnicus,
I hope this e-mail finds you well.
Same problem here, please help, maybe your solution can be applied to my TV: XBR65X850C
Thanks.
caio
