Sony KE-55A8 as Centre Speaker
KingPuck
Hi there,
I purchased a KE-55A8 TV to use the Acoustic Surface as a Centre Speaker in my 5:1 setup - driven from my Denon x4100W. Foolishly I did not check to see if this Model had Centre Speaker connections - it doesn't.
Can anyone tell me if there is a way of connecting the TV to my Amp Centre Channel to be able to utilize the Acoustic Surface?
many thanks
3 REPLIES 3
Acoustic Surface Audio in this model is from "himself"...
You can only use an external Central Channel.
KingPuck
Ok - thanks.
I thought that would be the case...
Bat_Rick
Hi KingPuck,
I agree with Marino, you can only use an external central channel.
