problem with alarm coming up 00:00 and it is not selected in the menu.
Hi @mommepigen, turn off all selected alarms (press the Input button - Timer & Clock icon - Alarm). If it still remains, try resetting the TV from the mains and check again.
Hi
All perfect, all works just right again.
Kind regards
Reinhard
