Hi guys,
I’m with the above setup but I cannot play Dolby Atmos/DTS:X via Bravia Core nor 4K remuxes.
The receiver in question is with HDCP 2.2, and it plays Atmos, DTS:X just fine via Nvidia Shield Pro or my Sony UBP-X800M2 player.
The same release that has DTS:X plays perfectly via UBP-X800M2, but it stays to PCM 2.0 if I play the same release from the Sony XR-65X93J.
My TV settings are:
eArc: Auto
Digital Audio Out: Auto 2
Dolby Digital Plus output
Pass through mode: Auto
I’m using HDMi 2.1 cable up to 8K
What might be the issue?
This may have been mentioned in earlier posts but have you set Audio Pass Through to Auto.
Press the Settings button on your remote.
Select Setting from the on-screen pop up.
Click on Display & Sound, then click on Audio Output.
Scroll right down to the very bottom of the list you will see Pass through mode, set it to Auto.
Hey there, check the below too:
-Update the amp: https://www.sony.co.uk/electronics/support/audio-components-receivers-amplifiers/ta-an1000/software/...
-And here: https://helpguide.sony.net/ha/strtaan10/v1/en/contents/TP1000735468.html
