Trouble with ARC on x900h
karbomike
Hi all
Having some issues with HDMi connection with my new speakers. My tv (sony x900h) recognizes the speakers by their name in the settings (klipsch the fives) , but I'm not getting any sound. I've set the audio out to PCM only, I've powered everything off and back on, tries a couple different cables.. no luck. Any additional advice or things to try ?
Thanks
2 REPLIES 2
royabrown2
Hero
@karbomike
https://support.klipsch.com/hc/en-us/articles/360043032612-The-Fives-Connecting-to-TV-through-HDMI-A...
You are using the one HDMI port on the TV that supports ARC?
You do have BraviaSync (Sony’s name for CEC) turned on?
(Sorry if these are obvious questions, but they are the first ones that need to be asked 😢)
HannahEd01
Hey karbomike, Make sure there are no headphones, you picked audio system, and royabrown2  advice as well. If you're still having problems then we can start troubleshooting.
