Fisher14
TV Channel Editor
Downloaded new Channel Editor and it looks good. My New tv picked up over 700 sat channels lots of duplicated etc. My question is if i edit all the programs and then export them back to the tv, when a new channel is available i assume the tv will scan all the channels to find them and then i will finish up editing over 700 channels again.
Am i missing something??
Many Thanks
3 REPLIES 3
Pascale_F
Hi Fisher14,
This seems frustrating - I'll just see if I can find anything out for you. Maybe someone else in the community can help in the meantime though.
Thanks,
Pascale
Fisher14
Thanks
Fisher14
Contacted Sony support and they say tv will only pick up "New" channels it wont oick up all the others that have been edited out.
Not sure if i believe that but time will tell
