TV SPEAKER SOUND 49XD8088
Gally36
CAN SOMEONE PLEASE ADVJSE ME HOW TO GET RID OF THAT SORT OF CYMBAL/CHING SOUND WHEN USING THE TV SPEAKERS, I HAVE A SOUND BAR WHICH HELPS BUT SOMETIMES WANT TO HSE THE TV SPEAKERS, CAN I HSE THE EQUALISER, IF SO, HOW.  THANKS
4 REPLIES 4
Anonymous
Not applicable
Hi there
Go to the "Sound" Settings and you should see an option called "System Sounds" - set this to "OFF"
The TV has an equaliser, goto:
Settings > Sound > Advanced Settings > Sound Mode Related > Equaliser
Gally36
HOW DO I HSE THE EQUALISER. THANKS
Anonymous
Not applicable
Have you tried doing the above in my first reply??
Gally36
HI, TES I DID TRY, BUT DOES NOT MAKE ANY DIFFERENCE, IT SEEMS WIRSE WHEN PEOPLE ARE CLAPPING OR HIGH PITCH SOUNDS, THERE JS A PEAK OF TINNY, CYMBAL SOUND.  IT DOES NOT HAPPEN WITH THE SOUNDBAR ONLY TV SPEAJERS, ITS LIME THERE US TO MUCH TREBLE.  HOPE THJS HELPS.  THANKS AGAIN.
