using remote for volume up then it keeps going OR volume down and continues going????
sneish
Hi,  I have a KD-49XE8005 (about 2.5 yrs old) and recently have had issues with the volume when using the remote I can press it and then the volume just keeps getting louder and louder and then when I get it to stop and try to decrease the volume the same thing happens the other way and before you know it volume is zero.
So annoying , has anyone had this issue and can suggest a fix?
Buttons not sticking on the remote and regularly take them out and put back in the remote.
Hoping to get some help :slight_smile:
10 REPLIES 10
shaz4473
Thanks for the update and also appreciate the timing as my warranty runs out in just over a week so have just claimed my 2nd remote under warranty.  I started this thread but have had to set up a new account as I have changed email and could not log in.I have taken a note of the All for one remote for next time.
