Hi everyone. I connected my external hard drive to my tv and watched some home movies but I have since deleted many of them off my hard drive yet they still show up a thumbnail (and still play) on the video menu on the TV as if the files are stored on the tv itself.
I've tried every thing to delete them off the tv but everytime i connect the hard drive up they pop on the tv's video list????
Please help!
Hi dagladm,
Welcome to the Sony Community.
I'd recommend clearing the cached data of the Video app by going to settings - Apps - Video - Clear cache and data.
It seems unlikely that the TV would cache a complete movie's worth of data (if not more), so are you sure that the files are no more stored on your HDD? I would also try searching the entire drive using the name of one of the files to see if a copy is hidden somewhere or to back up the data you need and to format the drive and put everything back on it then try it on the TV again.
Cheers,
Sean Mc
yea i had that problem too so went into system/settings apps and cleared the data for the video player app.
seems that clearing the cacheanddata for the video player app doesnt solve it as i pluggedthe portable drive in again to view some hdr demo videos which i have on it but it seemed to show icons for videos which i have deleted and are no longer on the drive. so no idea where is storing the thumbnails and metadata.
Hi @romipat
You may have tried clearing the cache of other apps already but....
Have you used a file explorer app at all?
Are you using another app to view the videos with?
Also do you close the apps properly after using them?
@jumpsuit wrote:Hi @romipat
Hi Jumpsuit I used the built in video/ media player app it seems to automatically scan any externally connected storage drive for photos and videos.
i cleared both the data and cache for that built in app but its still seems to give previews for content which has been deleted fron that drive assoon as i connet it and it rescans it, very strange.
i havent cleaed the cache for other apps as no other apps were used I do however clear the global cache under the system/storage section I havent sideloaded any apps onto my tv so no no file manager is being used on it. either
Having the same problem on a A8G OLED. Videos deleted on my shared NAS drive (UPnP?) still show up on my Media Player on the TV. I have emptied recycle bins, searched using a file manager from Windows and Android, used the NAS file manager directly, nada. The files just do not exist. And when you try to play anything, or enter the directory, the TV reports "Unable to play media" but still displays it in the menu! 😞 Arrg! Of course you can't play it, it's been deleted!
Contents shown by the internal app are sent by the DLNA server of your NAS, you better check if there is any option in it
