cancel
Showing results for
Search instead for
Did you mean:
HT-ST5000 sound bar - rear speakers
profile.country.NL.title
GauravKap
I wanted to check if anyone has used Sony SA-RS3S as the rear speakers with HT-ST5000. We have moved our TV to a bigger living room and now desperately in need of rear speakers which can complement the soundbar.
1 REPLY 1
pa3eia
Dit is het Nederlandse gedeelte van de Sony Community, met als voertaal Nederlands.
73's
Thanks about the Kudos!!!
