Can't set personalised ringtones for contacts
anushiak
I can't set individual personalised ringtones for my contacts. When I click on the contact and go to edit, there is no option to set ringtone.
How do I set a specific ringtone for a specific contact?
profile.country.RO.title
_alexdon_
Go to contacts-import-select from SIM.
alexdon
18 REPLIES 18
_alexdon_
Go to edit the contact,press the three dots and add ringtone.
alexdon
anushiak
There's no edit/ringtone option in the 3 dots
When I click on a contact, it goes to a page where there's the 3 dots (delete contact or send contact) and a little man with a pencil, which is edit contact. Click on edit, goes to a page where can edit the name, number, add more numbers. But nothing for ringtone.
_alexdon_
After you get to a specific contact and tap the little pencil,don't you get 3 dots in the right corner?
Try this link:
http://userguide.sonymobile.com/referrer.php?region=gb&product=xperia-c#!Adding-and-editing-contacts...
alexdon
anushiak
Nope, seems my phone is different. I've looked at that link before.
After No.1 and No.2, there is no 3 dots. After I tap the contact I want to edit, there's the pencil man and 3 dots (which is delete contact or send contact). After I tap the pencil, there is no 3 dots. Just the name & numbers & email. No option for ringtone anywhere
_alexdon_
This is odd.Try settings-apps-all-phone,force stop and clear data.Restart your device.
alexdon
anushiak
I did it, didn't work.
Does it matter if the contact is a sim contact or phone contact? Or if contacts are synced to google or not?
_alexdon_
The contacts should be on the phone.Are they on SIM?
alexdon
anushiak
Yes, on SIM. Should I change it to phone? How do I do that?
_alexdon_
alexdon
