Charging
RÉSOLU
CrimsonMagik
Visiteur
Charging
Is it bad to charge Xperia C overnight?
1 SOLUTION APPROUVÉE
Solutions approuvées
Hampus
Héros
You don't need to worry, the battery or the phone will not take damage by overnight charging/longer charging times.
As you can see at the following link under the headline "Improving battery performance", it's recommended to charge your device often:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-c#Battery.html
Voir la solution dans l'envoi d'origine
3 RÉPONSES 3
Uliwooly
No, it won't damage your phone
CrimsonMagik
Visiteur
does the battery won't be damaged too?
Hampus
Héros
