Is Toshiba micro SD-CO16GR7AR30 16gb class 10 VHS- 1 is compatible with sony xperia c?
RISOLTO
Fab_Gab
Visitatore
 I want to buy  Toshiba micro SD-CO16GR7AR30 16gb class 10 VHS- 1 online, because I found it very cheap.
But I wanna know if it is compatible with my Xperia C
 Thank You so much!
1 SOLUZIONE ACCETTATA
Soluzioni accettate
Rickard
Master
I don't have any card from Toshiba here to test with but any microSD should work as microSD is a standard.
4 RISPOSTE 4
Rickard
Master
Fab_Gab
Visitatore
Thank you for the reply !
But for you, what is the best memory card for Xperia C?
Tag (1)
Rickard
Master
There's no memory card that's "best" for the phone. You should buy a memory card of the size you need (up to 32GB).
The class of a memory card says how fast it is. I would recommend at least class 6. The faster the card the faster you'll be able to write files to it.
profile.country.RO.title
_alexdon_
I also recommend class 6+ memory cards,but Sandisk or Sony.
alexdon
