Lokesh0107
poor GPS
My c3 GPS is very poor it can not connect to GPS while using offline maps is anyone with same problem?
3 REPLIES 3
Thommo
Offline is a reference to maps using the internet and not GPS
Lokesh0107
I didn't get you Thommo could you explain me what am I doing wrong while using here maps offline..
Thommo
There are two types of maps - one for use with internet connection and two for GPS like Copilot or TomTom so if you are using the maps for internet connection but don't have one but think having GPS enabled will fix it then you are mistaken
