Screen Capture Problem and other stuff
AarnFrnk
Hello,
I have just recently bought Sony Xperia C C2035, running in Android Jelly Bean 4.2.2 in Malaysia. And I have encountered few distinctive problem:
  1. Screen capture option should appear after a long press on Power Button, unfortunately it only shows POWER OFF, AIRPLANE MODE & 3-Sound Mode.
  2. This finding leads me to think "How do I know that I have the original Sony Xperia C?"
  3. What method can I do that to ensure my device is not some China Phone imitation? Why do I say this..because in the Keyboard Settings, I found out that this phone actually has an unremovable Chinese keyboard.
Please treat this as important.
Thank you!
Hampus
Champion
If you want to capture a screenshot on your Xperia C, you need to hold the ON/OFF button + volume down(-) for about 2-3 seconds. Press these buttons with a good timing.
Send me your IMEI-number in a personal message and I will be able to check if your unit is for the Malaysia market. You can find the IMEI-number if you go to the dialer and type *#06#
Note that you are unable to unmark "Chinese keyboard" under Settings > Language & input, this doesn't mean that your unit is a chinese phone.
2 REPLIES 2
Hampus
Champion
AarnFrnk
Yes please. Please find out if this device is original or not.
Thank you! Slightly_smiling_Face
