XPERIA C SCREEN ZOOM ISSUES
mt03
Hi
I Have XPERIA C Device I M Facing The Problem That Screen Is Being Zoom Automatically While Typing Or Daling Number ....... Please Help I Have Replace The Mother Board Too .
profile.country.RO.title
_alexdon_
Disable magnification gestures and you won't get zooming.
alexdon
9 REPLIES 9
_alexdon_
You have enabled magnification gestures from accesibility.
alexdon
mt03
Yes I Have Enable Magnification Gestures
_alexdon_
alexdon
mt03
Okay I will Try This & Let You Know But What Is The Purpose Of Magnification Gestures ............
_alexdon_
Probably for people that don't see that good,they can zoom in.
alexdon
mt03
Thank You So Much I Will Try & Let You Now Slightly_smiling_Face Slightly_smiling_Face
_alexdon_
Keep us updated.
alexdon
mt03
Yes Working Now Fine Thanks Alexdon Slightly_smiling_Face Trophy
_alexdon_
Cool.
alexdon
