Attaching an external Mic to a CX250E
profile.country.en_GB.title
potkid
Have just purchased a CX250E. When I attach the external mic all I get is a humming sound - what am I doing incorrectly?  Without the mic sound works ok
Mick2011
The accessory mic should have a 3.5mm stereo minijack, with two rings on it. You might have issues with other types. Make sure it's fully inserted.
It sounds as if you have the right jack there: check the user manual p.14: the one you need is second from the top under the flap on the side.
Mick
4 REPLIES 4
blaireau_photo
Hello and welcome to the Sony Forums :slight_smile:
Out of interest, have you tried to attach this microphone to another camcorder or video device to see if you have the same problem. I am only asking this in case there is a problem with the microphone itself.
Thanks,
Simon
potkid
Hi - Thought about that last night but no have nothing else to try it one. When I purchased there was even doubt about whether the socket  (which is red) was even a mic socket although there is a mic symbol close by
Mick2011
Mick
potkid
Hi Mick
Think you may have it, jack has only one ring - will have to look for another mic
