Hi, I’ve got a blinking error message says “E:95:00” on my HDR-CX550VE. What does it mean? Thanks
hallo,
my camcorder hdr pj650ve flashes E95.00, what ca I do?
al erdberger
@a-chello wrote:hallo,
al erdberger
Hi there,
The reason for error "E:95:00" is actually very simple. It tell you that you camera battery is about to expire. Buy a new battery and your issue is resolved
Cheers,
Hi all,
according to the manual..
C'est ce qui s'appelle répondre à coté de la question. Very Sad
