Hi can anyone tell me how to get around the problem of not being able to see the LCD screen on a camcorder in the bright sunshine
Regards
Hi longman, welcome to the Sony Forums
This is a common enough problem which has only one real solution: try to film with the sun to one side, rather than behind you, perhaps shading the screen with a free hand.
If you have an articulated screen, turn it so that you get some shade. If the sun is overhead, for example, tilt the screen down a little: the viewing angle on most handycams is wide enough that you don't need to be looking squarely at it and you'll actually see the image more clearly.
Obviously if you have an optical viewfinder you can use that, but in general this is a problem as old as photography itself, and the reason photogrpahers used to stand with cloths over their heads! I'm not suggesting you have to do that, but it would actually be a pretty good solution... :smileygrin:
Mick
Mick
