Sony HandyCam and Windows 7
profile.country.en_GB.title
kibooth19
Are  any Sony Handycam compatible with windows 7 64 bit operating system
1 REPLY 1
Mick2011
HI klbooth19, welcome to the Sony Forums.
OS compatibility is really a question of the PMB software version required for the camera, and I believe most recent HandyCams use PMB v5.6.02, which is Windows 7 64-bit compatible.
If you have your eye on a particular model and want to check, go to the Sony Support page for that model. Under Downloads you'll see the PMB link and applicable version number.
Hope that's of some use :slight_smile:
Mick
