Hi everyone,
I've search the forums and internet without any luck. I have a Sony CCD-TR427E HI8 Handycam. I can't seem to find out what under water housing case would work with this model? If any...
Any help would be amazing from you're kind selves!
Hello tjmoto - Welcome to the Sony Forums
I seem to be having the same issue as yourself when looking for a specific underwater housing for this model of camcorder. However, it may be possible to purchase a universal camcorder housing as long as you measure the exact dimensions of your camcorder. I have seen that there is a company called Aquatix which manufactures these housings as well as a few other possibilities - if you put 'Aquatix' or 'Universal Underwater Camcorder Housing' into Google you will be able to see further information about these.
Thanks,
Simon
Thanks,
Simon
