lens does not come out
profile.country.el_GR.title
delos69
Hi. i own a DSC-W50 and all of a sudden while i started to snap some photos the motor of the lens couldn't push the lens out. i receive a message to turn the power off and on again but nothing happens. It makes a slight move to push it out but nothing more. Does anybody had any kind of problem like that? Is there any solution to this problem?
profile.country.en_GB.title
blaireau_photo
Hello delos69 - Welcome to the Sony Forums :slight_smile:
This sounds like a mechanical fault within the camera if you can hear the mechanism try and retract or push the lens out without any success. If you have already tried doing a master reset of the camera, it may need to be repaired by a suitable service centre.
You can find out more about getting a repair from Sony by getting in touch with customer services - full details are available in this forum thread here:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon H
1 REPLY 1
blaireau_photo
Thanks,
Simon H
