- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I use Sony's PMB program for importing pictures to my PC. The problem is that if I choose to automatically create a new folder for every new event, the folder that is created, which is named by date, is of the format dd-mm-yyyy so the folders cannot by sorted correctly. Is there a way to make the automatic format yyyy-mm-dd?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi broglet, welcome to the Sony Forums
I believe PMB will reflect the settings you use in Windows' Control Panel, as there's no option I know of to alter the date format within the program itself. Incidentally, you do that using Customise in the Regional settings, not by changing the Date & Time settings...
You could also try an alternative image browser: Windows Live lets you do this, as does FastStone http://faststone.org/index.htm Both are free downloads.
Hopefully one of those solutions will give you what you're looking for.
Mick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Mick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It is possible to manually change the import folder name each time the PMB import wizard starts. But the DEFAULT folder name will always be in the dd-mm-yyyy format
