AlansCamera
RX10M4
Does anyone know where I can get a larger rubber eyepiece/eyecup for my RX10M4?  I'm looking for something like this...... eyecup.jpg
jumpsuit
Hi @AlansCamera
I'm not sure anyone has made a larger eyecup for the RX10M4.
3rd party companies may have made replacements but I'm not sure if they're larger.
Some people online that also wanted a larger one have used a rubber sleeve which you can stretch over the eyepiece and have said it worked.
Have a look Here
Hope this helps.
3 REPLIES 3
jumpsuit
Hi @AlansCamera
Have a look Here
Hope this helps.
AlansCamera
Many Thanks jumpsuit
jumpsuit
Hi @AlansCamera
You're welcome :slight_smile:
