Error whille updating new firmware 11.3.A.2.23
vamsiformandhra
i am not able to update my phone using Sonu pc companion or update services,
i trier in 2 different PCs, Please provide me any solution.
this is how i tried
i connected my phone and new update is available
after downloading update it prompt me to switch off and wait for 30 sec and hold volume  down key while connecting,
i did that it detected and flash driver is installed next after 5 min itsays try again with full batery charge,
tried to off firewall,disable antivirus aut no result found,
PLEASE SUGGEST ANY SOLUTION
shihstouch
Enthusiast
Here we can Restart your phone, follow below instruction to do so...
Restart
Restart your phone to turn off all running applications and to remove memory blocks. Remove and reinsert the battery and the SIM card. Then restart your phone.
GIVE A TRY
After update with SUS...
11 REPLIES 11
shihstouch
Enthusiast
What is your battery % , u need more than 50% battery to perform a update...
vamsiformandhra
my battery is above 95%..
amitdgp06
U r from India or others country?
vamsiformandhra
From india Bro...
i contacted coustmer support also but no use...
shihstouch
Enthusiast
Restart
GIVE A TRY
vamsiformandhra
Thanks Bro.. its worked..
even thought i tried previously as you said it wont worked
but now i removed sim card and restarted with out inserting sim then i tried then it started updating.
now its successfully updated.
shihstouch
Enthusiast
Happy to hear that Grinning_Face
vamsiformandhra
Crying_Face
i updated my xperia E with latest firm ware and i noticed that they have removed
sorround sound settings option in sound enhancments in WALKMAN.
xperia support telling that with new update this surround sound option is removed.
shihstouch
Enthusiast
Please make a new thread ...
It will help you better...
Thanks
