How to turn off TalkBack and accessibility
Littlesid1
I have set my xperia e phone to text to speech and can not turn it back off anyone got suggestions please
Topic edited by Rickard
30 REPLIES 30
Rickard
Master
I see your problem is already solved but in case anyone else encounters this and is not able to scroll in menus you need to use two fingers to scroll if you also enabled explore by touch under Settings ->  Accessibility.
Reetika
Thank you Rickard!!!
Your solution worked!!!
Kanwaljit
Its very easy to disable talk back. if you are unable to reach upto accessibility button. Do this.....
1.Just keep your double fingers on screen to scroll up and down.
2.to select any app touch 1+ 2 times every time to select any app
If problem persist.... Pl call me... removed by alexdon (INDIA)
coco425
Cause
TalkBack helps blind and vision-impaired users interact with their Android devices more easily.
Resolution
Below are tips you can use regarding the TalkBack feature:
Turn on TalkBack feature
From Home Screen tap Applications.
Tap Settings.
Tap Accessibility.
Tap TalkBack.
Tap the slider to turn it On.
Tap Ok.
Turn off TalkBack feature
From Home Screen double tap Applications.
Double tap Settings.
Double tap Accessibility.
Double tap TalkBack.
Double tap the on / off slider to turn it Off.
Double tap Ok to stop TalkBack.
Touch Selection: You must double tap the screen to activate or select screen icons and options.
Scrolling: You must touch the screen with two fingers and slide up or down to navigate through a list.
Swiping: You must touch the screen with two fingers and slide left or right to swipe from screen to screen.
Dionie
swipe with your 2 fingers to scroll down
vijaysharma
i cant use my phone because of the talk back button please help me
profile.country.RO.title
_alexdon_
Use two fingers to drag down notification bar,you need to tap two times to select an option.Go to accesibility-talkback.
alexdon
abcmyfavorite
You could swip down or up in settings and go to accessibility WITH TWO FINGERS.
Lisa
The solution to this is, use 2 fingers on the screen to scroll, 1 finger scrolling doesnt work, accessibility is intended for blind people I think, so to avoid accidental navigation they made it multitouch. no need to reset the phone, hope  this helps
surya979
for scrolling down double tap and scroll down then it works.
