I dropped my Sony Xperia E3
af78
I dropped my Sony Xperia E3 on the top right hand corner, now the image is blurry but the screen isnt cracked.
Help!
Thommo
You need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
2 REPLIES 2
Thommo
Amikpami
I've lost my Corner bumper.. where should I'll get it???
