LED doesn't blink for missed call and new message
Sridhar1994
I bought Xperia E single sim (C1504) a month ago it woeks pretty well so far but the only problem which crept in after the update is that the L.E.D notification light is not blinking when I receive a message or a missed call.plz help me
Topic edited by Rickard
Cot88
Enthusiast
Check if on your mobile is available the feature "stamina mode" for battery management
If yes, turn it off
5 REPLIES 5
Cot88
Enthusiast
If yes, turn it off
shelovesicecrm
i had the same problem, it can be abled if you restart your phone.
Sridhar1994
hey thanx ive turned it iff and its blinking again!!!
ronit9009
some time my 3D surround sound enhencement is stuck at playing and lilttle pause at playing how i m solve that problem how?  it's not listen continue in smooth as sony ask!! i bought that phone just 3 day ago reply me pls
Sridhar1994
umm turn off the surround sound and it will be smooth again! if you are using single sim then update your phone
