- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2013
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
10 REPLIES 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
all i have installed are 2 games and 4-5 other apps and all are moved to sd [those which can be moved]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
Can't even install apps now .....removed most apps still......
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
The phone takes 80 mb for the messaging services and all and you have used most of it and only 70 mb left so it is showing like that
its not a problem just give 80 mb to the phone and remove google app updates then it will be good
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
it is good that you have es file explorer
just open it and run the sd card analyst
the dcim folder contains 2.big files just delete them you will free up around 500-600 free memory.
make sure you delete them regularly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
and also don't update the apps that you are not using.
also uninstall chrome updates as there is nothing new in it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
did you got those toggles in notification bar after update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Power toggles app
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
How about if you clear data for media storage in settings-apps-all?
alexdon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
clearing data also works but it gets created again when you use that respected app
