Problem with Facebook after update to Android 4.4 the solution doesn't work
peterpan62
I cant't repair  with  pc companion the message "su telefono esta actualizado .... no existe software para este dispositivo . And can't install facebook my phone is not compatiple
Tags (1)
peterpan62
I've solved the problem whith de following instructions form your technical SERVICE .
Dentro del programa Pc Companion, inicie "Support Zone" sin conectar el cable USB, cuando seleccione "Actualizar software", le indicará que no detecta su terminal y que si tiene problemas con el mismo "Repare" el teléfono. Seleccione esta opción y siga las instrucciones del programa. Conecte al cable USB unicamente cuando el programa lo indique.
Thanks
3 REPLIES 3
profile.country.RO.title
_alexdon_
Is this the problem you have?
http://talk.sonymobile.com/t5/Xperia-E1-E1-Dual/Problem-after-upgrading-to-kit-kat/m-p/814479#U81447...
Beware that it is Xperia E thread.I will move it accordingly.
alexdon
peterpan62
Thanks
_alexdon_
So you have tried a software repair,correct?
alexdon
