Problem with software updating
nicolasmart
Hello! I have a Sony Xperia E dual (C1605). This site says that "The last update for this device is:Android 4.1.1 Jelly Bean", but when I open the PC companion program ( I have installed pc companion from my phone. It says "Do you want to install PC Companion" and i click yes) it shows me "You have got the lastest update", but I have android 4.0.4 ics.
Can anyone help me to do this update succesfuul? Please!
Stanly_CK
The update is available in your country, my friend.
About that repairing... I'm not quite sure about that.
12 REPLIES 12
profile.country.RO.title
_alexdon_
Is your phone locked to a specific network?
alexdon
nicolasmart
No, it isn't. It's unlocked.
_alexdon_
It might take some more until an update reaches a specific country.Ask xperia care more:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
Stanly_CK
The update should be available everywhere since last December. Maybe you should take it to your nearest Sony centre.
nicolasmart
Can you tell me when it will be available for Bulgaria, Europe?
Stanly_CK
It is already available. No idea why you're not getting it.:smileyconfused:
My suggestion is go to the nearest Sony centre and ask for some help.
nicolasmart
But if you can't tell me when it will be available for my country, can you tell me can i get this update with clicking on "Repair my phone"? It tells me that "Click on the link to re-install the lastest available phone software for optimal perfomance". Can i click it or it might take a problem? Is it risky?
Stanly_CK
nicolasmart
Ok, thanks! I will do factory settings or just...Go to the sony center.
