- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Good morning, i have a problem with my e4g.
When I have a call without answer, crash the telephone application, so I lose the signal and the connection until after a lot of times that i click on the continuous notice, the signal return.
I believe both to impute to a not correct operation of the incallui, but I cannot for example erase the cache because the incallui.apk I see it only through an external program, not from the list applications and so I cannot also disinstall it.
I cannot go in safe mode because the Phone remains 10 minutes or more on screens with the blue waves of loading, without show me more therefore I have click the reset button.
I have already update to the new firmware but the problem still remain.
Some idea that isn't factory reset?
Ps sorry for my english, i'm italian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @AndreaMorph
Please, try first run a backup of the device information as explained here. Then perform a system repair using PC Companion or Bridge for MAC. This will factory reset your phone and erase all data. You might need to charge your device for about 1-2 hours before so the device has at least 80% battery. Make sure the device is not connected to computer or laptop and turned off until you are prompted (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device). Start PC Companion -> Support zone -> Update my phone/tablet -> Blue Repair my phone/tablet -> follow instructions. When prompted connect your phone still switched off holding volume down or back button. The repair or reformat process will start. If you are using Windows 8/8.1 or a 64 bit operating system adjust settings for PC Companion and run in compatibility mode -> chose Windows 7 or XP. I´m at disposal for any question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @AndreaMorph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
maybe 2 - 3 years old, but i don't know if is this the problem because if i make o receive calls all is ok
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
why the size of the sim card affect only missed calls and not outgoing or incoming calls ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @AndreaMorph
Have you try a repar with PC Companion or Bridge for MAC as I suggested above?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
when i come back to home i'll do the backup and i will try the reset if there isn't more solution!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @AndreaMorph
Good, keep us updated please. I´m at disposal for any question.
