wifi problem and music equalizer
ca8erpillar
wi fi shows connected but pages aren't loading! what to do?and, is there any equalizer setting option in music?
Hampus
Champion
I suggest that you take a look at the following FAQ-topic:
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104
You should be able to find the equalizer if you go to Walkman > Menu button (the one with three dots) > Sound enhancements > Equalizer.
2 REPLIES 2
Hampus
Champion
ca8erpillar
thank you so much.that "clear audio+ " thing was activated so i got skipped that option for equalizer.
