Xperia dual E3 restart problems
PoornimaE3Dual
I bought an Xperia E3 Dual just couple of weeks before. I am experiencing restart problems in it. Upto 20 25 times a day. First light will go off then it switch offs itself for 5 10 minutes. i am not able to properly call or do anything properly due to this. Please help me as I have spent my hard earned around 13k for it.
13 REPLIES 13
Uliwooly
The problem could be an old or faulty SIM card, if you trimmed/cut the SIM card to make it fit, that could be the issue, remove the SIM card, if you don't expect a restart then you know its the SIM card.
Uliwooly
You can also boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
if the problem its gone then its an app acting up, just repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
Jake-SonyXperia
Champion
Hi PoornimaE3Dual,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
This may also be related to an SD card, make sure to remove it if issues continue after going through Uliwoolys instructions
That is if you currently have one in the device.
Keep us posted.
pkd1
I bought an xperia e3,, I experienceing many auto restarting problems,, please guide me,,
Krishan1
i am facing sony e3 dual restarting problem in 15 to 20 times in a day.
what is solution. plz tell me.
arun1979
Sir,
I am having Sony xperia E3 dual phone. My phone got stuck at starting screen with sony logo. I have tried to format my phone using SONY PC Companion as well as Flashtool but to no avail. Both the applications are not detecting my phone. I have even tried with different USB cables but no output. Please help me out.
sssddd
sir,
I have Experia E3 dual and I am facing the problem, my phone is stuck on the sony logo and blinking contineously from last 2 days please help me .
NitishR
Since your device is not getting started there is no way that PC Companion will detect your handset so PC Companion is not of any use
Uliwooly
@NitishR
PCC is no longer supported.
