I was doing system repair on the xperia e4, using the Xperia Companion, there was error and when trying to continue, it does not continue. And now the phone doesn't get any more charge on the battery.
Is there still a solution or is it a lost case?
I'm sorry to hear that, what if you connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours > then try to turn it back on
I've done what you said.
The phone just flashes the screen and vibrates as if it would start charging, but does not start.
I wanted to know if I switched the battery for a new one, it would be possible to reinstall Ron, having been interrupted the previous installation.
(Before that, the phone was shutting down and discharging the battery from 80% to 0% instantly.
Thanks for helping me.
