:smileyangry:hello i have had my reader for about 3 weeks and each time i have downloaded the books they are protected by some kind of rights and i cant read my books please help otherwise i will be taking it back to the shop as i have had enough!!!
I think we need some more details:
- which model are you using
- are you using the reader software delivered with your product or a 3rd party one?
- which store are you buying from
Anything you can add in what steps you actually take.
Kindest regards,
Nico
