Hi, I recently bought a used Sony Nex-5 base model because I wanted to start taking some nice photos during my vacations, however, after removing the protective screen included with the camera the anti-glare coating of the screen also came off.
It didn’t bother me much, I ordered a new screen and I will replace it; after ordering the new screen I also thought that I could also replace the screen plastic frame because mine has a small crack (nothing serious, it is just cosmetic, but I’d still like to replace it if I can), however I can’t find anywhere the piece that I’m searching.
Can anyone help me find it (the silver version), if it still exists? I would really appreciate it.
I’ll link a picture I found online.
Hey @Mat3800
I believe these parts are only available through Sony authorized service centre.
I'd suggest that you contact them using their direct contact number: 01656867250 or email: scs@sony.com
303 - A-1779-732-A PANEL BLOCK ASSY (SILVER)
