profile.country.en_GB.title
scrobin72
apple connectivity
is there any way i can make my sony camcorder work with my apple macbookpro. camcorder is a dcr-sr30
Message was edited by: scrobin72
Watashiwateshdes
Contributor
The easiest way is going to be connecting via USB and powering on your Handycam. Once done, use the touchscreen to select the option you require.
Ideally your video editing software should detect the content and give you the options to import. If not, you will need to browse the folders and copy the videos manually before viewing or editing.
If you have already tried this, could you please elaborate so we can try and help out more.
2 REPLIES 2
Watashiwateshdes
Contributor
nkhan1407
Hi
I have a sony camera and camcorder which i use to take videos but when I try and import them to my Macbook
the file format is not compatable to edit and view. please can you prodvide some assistance? ... many thanks.
Kind Regards
Nkhan
