DPF-D70 Digital Photo Frame Help
Hi
I'm thoroughly stuck.
We have just re-found our Sony digital photo frame that we purchased ages ago and then moved house and forgot about. The problem is that we have no idea where the adapter is for it, it didn't seem to be in the box and sin'ce we've never used it we are a bit confused.
Regardless of that can anyone suggest where to find a suitable adapter for this frame as the only option so far seems to be to buy a very expensive second hand one from America and I'm just not happy to do that. I can't find a replacement adapter anywhere via Sony.
It says "Only use with Sony adapter AC-P12Vx".
Any help and advice would be greatly appreciated. Thank you
Anonymous
Not applicable
Hi there
A good place to go could be Maplins - They may be able to match up a suitable adaptor for this (a generic one though).  It would help them if you print off the specifications, pages 39 and 40 of the manual : HERE
Good Luck
EDIT: And bring the photoframe with you :slight_smile:
1 REPLY 1
Anonymous
Not applicable
Hi there
Good Luck
