- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
You can use:
---CompactFlash card
---Microdrive
---MemoryStick Duo (using a MemoryStick Duo Adaptor for Compact Flash Slot: http://www.sony.co.uk/support/en/product/AD-MSCF1 )
( More info on pag.21-24 http://download.sony-europe.com/pub/manuals/consumer/DSLRA200EN.pdf )
-MemoryStick Pro Duo
-MemoryStick Pro-HG Duo
Jannis
PS. Example AD-MSCF1:
Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jackal38 and welcome.
The A200 can use Compact Flash media or MemoryStick Duo with an adapter. This is copied from the specifications for that model: -
Compact Flash Type I / II / MicroDrive slot. Memory Stick Duo / MS Pro Duo and MS-PRO HG with optional adaptor
Both Compact Flash and Memory Stick Duo are readily available from almost any camera shop - Jessops/Dixons/Currys/Maplin or online from Amazon or eBay.
If you use MemoryStick Duo you need the optional adapter: -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
You can use:
---Microdrive
Jannis
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you Jannis very helpful this should rectify my problem again many thanks ,kind regards jack
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jack. You’re welcome!
Jannis
