SYSTEM ERROR after trying the Wi-Fi / Bluetooth
JEGS578
SYSTEM ERROR - I went to use the Wi-Fi setting and it triggered this System Error. It turns on but then comes up with 'System Error' after a few seconds. I can't access the menu without it tripping out so it's stuck in this cycle. Have taken the battery out, changed lenses, changed cards, changed modes, nothing works.
I know many of you have had the same problem, can you let me know in the comments if you have? And has anyone managed to find a solution other than sending it back for a motherboard replacement? I am a couple months out of warranty and can't afford the cost of a new motherboard!
1 REPLY 1
TheGOAT
@JEGS578 I guess the camera needs inspections as it's a hardware issue, what is your camera model number btw?
