USB Flash Drive write-protected automatically by my Sony Bravia KD-55XF8096
ExcludeT
Hello,
I have a problem- My Sony Bravia KD-55XF8096 has automatically write-protected 2 of my USB flash drives (When I plug the flash drives out of my TV and then plug them in to my PC for example, I cannot rename, delete (or even on one of them I cannot add any content anymore ...). That was actually the reason why I bought a second flash drive because I was not able to remove that stupid protection from the first one. I also tried everything possible to remove that protection from my  PC but it seems that it should be done from the TV. So my questions are these:
1. How can I remove that write-protection from the flash drives?
2. How can I deactivate that auto write-protection done from the TV itself?
I just want to have full control over my flash drives from every device I have without any restrictions from the TV.
Thank you in advance for the response! ðŸ™‚
1 REPLY 1
Win_88
Specialist
Try this:
HOME button, then select [Settings] — [Watching TV] — [Recording device setup] — [HDD deregistration]
