What Is My Status?
profile.country.en_GB.title
Tonislegs
What Is My Status?
Hello Everyone,
This may seem a dumb question to some but I keep getting emails telling me that I should log in and "Update My Status".  What is this all about and how do I do it? I've not been able to find anything dealing with status on the site.
Regards,
Toni
Thalamus.
Champion
Hi Toni,
the email is just prompting you to update your status on the forum..
To do this click on either your Profile Picture or Q&A Username.
This will open your Q&A Profile Page.
Under your Q&A user name you should see a link 'Let others know what you're up to'
Click that link, a box should appear allowing you to update your status..:smileyhappy:
7 REPLIES 7
doverrog
Yep,
I'm getting the same emails and like you I can't see anywhere to input a Status.
Your Status
You haven't set a status update. Log in and set your status.
Can someone from Sony support please answer this one?
Thanks
Thalamus.
Champion
Hi Toni,
doverrog
Thanks Thalamus.
I've done that. Mystery solved.
Thalamus.
Champion
You're welcome doverrog, thanks for the feedback..:smileyhappy:
Tonislegs
To everyone that replied, thank you so much for taking the time and trouble to do so.  At long last I know what my status is, isn't it murder being a technophobe!
Best Regards To All,
Toni
doverrog
Yep. I've got mine worked out now thanks to Thalamus.
Thalamus.
Champion
Glad I could help doverrog..:smileyhappy:
