Hi. Does anyone know where to get a new mains transformer for my STR-DE685?
According to servicemanual, the partnumber is: 1-435-434-11.
//Olle
@olleblom wrote:According to servicemanual, the partnumber is: 1-435-434-11.
Hi olleblom, are you sure that is the 1-435-434-11 correct part number? I did a search and located the partnumber on a US suppliers site but they show different compatible models for a STR-DE825. I guess they could be wrong but according to their site the part you need is 1-437-699-11 but seems t's not available. Might be worth contacting them direct customerservice@encompass.com to see if they can assist further?
Hi again. Thanks for the quick response.
You´re right - wrong p/n, should be 1-435-903-11 (T901), and the STR-DE685 is used in Europe (240VAC).
//Olle
